finsends
Hello,
I have a fairly big property and to get power to the house, there are several metal poles with the cables running along them.
I had multiple issues with lightning strikes and suspect that the lightning hits one of the poles and reaches the house through that route.
Additionally, the negative wire has no insulation. Does a lightning even care about the insulation on the cable? On the poles along the road, I saw these big insulators between cable and pole. Is it necessary to but those between the cable and the pole, because right now, the cable directly touches the pole.
Thank you for your answers.
