schoe
Hi all, just a quick question when doing an insulation resistance test on a 2 way lighting circuit do both switches have to be open at the same time to get a <500 m result, because when they are both open and both closed I get this result, but when one switch is open and the other is closed I get a Lower reading?
Also if I leave a fluorescent light connected but remove the bulb would this still affect the insulation resistance result?
Thanks very much Chris
