schoe
Hi all posted this issue about a month ago and I'm still having problems.
I'm doing an insulation resistance test on a ring circuit,
L-n 500 mega ohms
N-e 500 mega ohms
But L-e is around the 150 mega ohms reading.
I no this is still well within the regulations but it's new cable so I don't no why I'm not getting 500 mega ohms as well.
The room was plastered and painted about a month ago so things should have dried out now so I'm pretty sure I can rule out damp as that was suggested before.
This is my issue, I've broken the circuit down and tested each leg individually and when I do this I get 500 mega ohms on each leg some of the results are more laboured than others but it does reach 500. It's only when I connect everything back up together do I get the lower reading.
I've been testing from the consumer unit with the wires disconnected from the breaker and bus bars so it can be parallel paths either.
If anyone could shed some light would really appreciate it. I don't understand why my live to neutral and neutral to earth are fine but the live to earth isn't.
Thanks very much,
Chris
L-n 500 mega ohms
N-e 500 mega ohms
Thanks very much,
Chris
