I
iwire4
I have recently qualified and am coming towards testing a re-wire. I have fitted 30 low voltage downlighters with transformers. Apart from removing the bulbs do I need to do anything else before pumping 500volts through the circuits. ie will 500volts damage the transformers or are they removed from the circuit before this test, or done at 250volts? This has not been properly explained to me.
Any advice greatfully received.
Thanks.
Thanks.
