Hi guys new to this website just a quick question as it has been a while I have a small 6 way distribution board this only becomes live via a time clock supply wired into it I'm going to be testing this board with a IR dead test on each circuit just to make sure according to guidance note 3 & on site guide all voltage sensitive equipment must be disconnected each circuit will have its neutral conductor removed from DB should I also be disconnecting this time clock supply to the DB also as these have relays in them this could affect the IR reading obtains at time of testing and inspection just to clarify appreciate any help on this matter
thanks guys
thanks guys
