insulation resistance test on equipment with high earth leakage | on ElectriciansForums
Guest viewing is limited
Discuss insulation resistance test on equipment with high earth leakage in the Australia area at ElectriciansForums.net
daisy
Hi guys.
This is to do with Periodic Inspections. When you are testing a circuit and forget to unplug a piece of equipment that has a high earth leakage could this be damaged doing the ins res test between live and earth. I do not know electronics but is there a connection to earth. The problem has always been, up to now, live/neutral test but i now have doubts about live/earth. Interested to see your views.
Thanks Daisy.
You could certainly damage the filters/surge suppressors on the input of the equipment.
Try to remove all equipment.
Test at a lower voltage first. If you get leakage, don't go to higher voltage without investigating first.
Maybe, I wouldn't like to try it. Always test at 250v before you do 500v then if you get a low reading you can investigate why (eg equipment plugged in) before you risk doing damage.
Thanks guys.
That has been my trick over the years,start with 230v and see if it is a low reading live/neutral to earth. But someone has said to me this could damage equipment because the test voltage is DC.
Any thoughts.
Thanks Daisy
Reply to insulation resistance test on equipment with high earth leakage in the Australia area at ElectriciansForums.net
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
There can be a few reasons for low L+N -> E readings: Connected equipment is leaking. By design, or just old/damp SPD are connected (but there...
