K
kathleenbilly
Hello to those looking in,
My question is on Insulation Resistance testing.
The senario, PVC Conduit Singles 1.5mm two way light operating fluorescent tube lamps.
Now as i understand it the above fluorescent lamp have both a starter and a ballast. If a insulation resistance test was done ie: 500v sent down the live and neutral this would blow the ballast.
My quiery is if the light switch is in the off position would the insulation resistance test voltage/current only travel as far as the switch? Thus the fluorescent ballast which is sensitive be safe, if so how does this apply on the two way light switch how do you confirm they are both in the off position.
I also have heard that you can connect the live and neutral together and test between them and the CPC and this method protects sensitive equipment?
Can someone explain the benefit of this why it's used and where this pinciple is best used, i really need to understand this i don't want to ever damage equipment or any sensitive systems.
Thank you KB
Thank you KB
