Insulation resistance testing - combined L & N test | on ElectriciansForums
Discuss Insulation resistance testing - combined L & N test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Sheffield
Good Morning all,
When you are doing the combined L&N to earth test on a circuit that contains vulnerable items, do you record the result in all 3 columns ? And do you have to mark the results that you have done the combined test?
Reply to Insulation resistance testing - combined L & N test in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
Continuity of the suspect cable appears fine all cores, from this I could work out the length of it and it really doesn’t appear looking at the...
