schoe
When doing an insulation resistance test on selv spots what's the best way to do it without disconnecting all the transformers?
Can you do a complete consumer unit insulation resistance test by linking the live and neutral bars together and testing between earth on a 500 volt test or should it be 250 volts?
I assume in the paper work it goes down as a limitation?
Oh and last one on the schedule of test results for the niceic domestic installer the test results for insulation resistance says test,
L-l,
L-n
E-n
L-e
What does live to live mean?
Thanks chris
L-l,
L-n
E-n
L-e
Thanks chris
