insulation resistance | on ElectriciansForums
Discuss insulation resistance in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
M
mikey12
hi all doing a bit of insulation testing on dummy board not too sure:confused: which is why im asking have tried doing tests on circuits with meter keep getting reading >999 would this be correct as this is the max meter will go any help appreciated
This is correct reading for healthy clear circuit.
Have you checked your meter by shorting your leads and testing?
Your reading should then be 0.00
many thanks sintra as i said wasnt sure and its best to ask also yes shorted leads and also got 0.00 thanks again:D
this reading would also be used on certs if im correct
>999 that is not 0.00 :eek:
Reply to insulation resistance in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
There can be a few reasons for low L+N -> E readings: Connected equipment is leaking. By design, or just old/damp SPD are connected (but there...
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
