insulation resistance | on ElectriciansForums
Discuss insulation resistance in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
G
Geoff76
Hey, need a little help,tncs, power off main earth and neutral disconnected from board, did insulation resistance between n and earth, kept getting 0.16 reading, i have a fault, i wonder is a cable nicked....
so dis. each circuit in turn from CU terminals and find out which one is giving the poor reading
Reply to insulation resistance in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
If the main switch is on when testing global IR then the neutral and earth will likely give a very low reading. Not that anyone would...
loz2754
L
