First, thanks to all for your contributions!
Al, the full story is this: I decided to have my home tested recently. We're about to do some renovations and I figured that if the there are any electrical problems, now is the time to pull the house apart, rather than afterwards.
The tester reported that there was "low insulation resistance" and that further work would be needed to determine which circuit(s) were responsible. I have been given a provisional quote for this and for repairing the circuits that have a problem.
However, it is a complicated period house in which that all mannerof electrical additions have been made over the years. I'm guessing that the work could take quite a bit longer than the tester has allowed for in his provisional quote, so I figured that I could save myself some money by doing some of the investigations myself.
Ideaaly, when the tester ret.urns, we will have a much clearer idea of where the problems lie.
So I've purchased a s/h Fluke 1503 and educated myself as much as I can on the procedures of IR testing.
I have noticed from posts on this forum and elsewhere that one method is to join the L's and N's of a circuit together and test to earth. It seemed to me that this would save time by not having to remove all my light bulbs, dimmers, neons etc etc. Hence my post!
The other factor here is that the Fluke 1503 does not have a 250V setting, so everything will have to be at 500V.
So there you are Al, you asked me to 'spit it out'. There it is!
Tim
