Intasol valves? | on ElectriciansForums
Discuss Intasol valves? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Steve_rutland
Has anyone got any experience of these units? I'm looking at doing a plate heat exchanger ( for mains pressure ) with vented tank system and was going to use zone valves for control. But, then I stumbled on these. Any ideas?
Reply to Intasol valves? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I
Baxi system boiler and Opentherm Hello Does anyone know if its possible to connect an Opentherm thermostat such as a Nest to a Baxi 800 System...
Ian777
I
The 4 pumps are :- 1. boiler to cylinder 2. C/H and UFH circulating pump 3. UFH dedicated pump after manifold 4. DHW circulating pump. (this just...
