H
highspark
Intercom not working on electric gates installation. 2 seperate gates with 2 intercoms in parallel and one phone operating from the 2 comms.
Comms are fed from 240v - 12v PCB/transformer. On the out side of the transformer is 0v 12v ac and another that is 0v +12v dc.
Fed from 0v 12v ac terminals is the light which highlights the name card. I got this working by changing the fuse/bulb.
However from the 0v +12v dc this goes straight to the intercom panel. But the panel itself is not working. Usually the bell/button is alight wen working and buzzes when pushed this isn't happening on either.
When testing across 0v +12v do I get no voltage???? Is this correct or should I be getting 12v? If this is the case is the transformer nackered?
