dandb
A friend of mine is purchasing a house and has asked an interesting question. He has seen the EICR for the property, which the home owner had, and the only thing he can remember seeing was the absence of an RCD.
He knows the property does not have an RCD on his inspection but it is pointed out only as a code C, requires improvement, on the EICR. And the form has been signed satisfactory with no remedial work.
Now the property has a front and rear garden so I would assume the socket outlets that can be used by ordinary persons to power outdoor machinery/equipment would be a Code B and the others, regarding absence of rcd for cables, shower room etc, to be a code C.
Now I would have thought even if they have put absence of RCD as a Code C, then it would still be unsatifcatory as a result and remedial work would be required.
Anyone got any views opinions. What do you put down the absence of an RCD is a property on the EICR form as I have always failed them saying remedial work required.
Thanks in advance.
Thanks in advance.
