F
FB.
Not being "one of the trade", I said that I would stop posting on here - but I found this observation to be too interesting to not mention:
Two adjacent solar PV arrays, mounted on near-identical houses, facing near-identical direction (SouthEast) and neither with shade issues, taken at 9.45am (mostly bright and clear since daybreak), today (10th February 2012), after a couple of cm snowfall overnight.
Very interesting to see that one of the arrays has cleared the snow much better than the other.
One array is 15x250W panels, the other is 18x190/200W panels (I think).
Looks like someone has got the polish out on the left house so the snow slides straight off! :D
a few factors could solve this, if the house on the left has a new born baby in, the people will be running the heating on alot more and higher, that could cause alot more heat, also depends on the insulation in the loft, and just one small slip of the snow at the top is all it would take for the whole column to come sliding down.
just my thoughts
one might have an attic room ? you get "Selfcleaning" Glass coating could it be applied to panels?
Panels have not had special coating (other than anything applied by the manufacturer). Both arrays of very similar age (a few months).
Neither house has any major changes in the loft such as an attic room to affect heat exchange - and the amount of snow remaining on the tiles beside the panels is very similar for both houses; suggesting comparable heat loss through the roof.
Maybe, due to orientation, as the sun came up it hit the roof on one house just a little before the other. because of shading from neighboring houses,
The sun is still very low in the sky, just a thought..
Have a look early tomorrow if the sun is shinning.
More likely one house has better insulation than the other.
That was my immediate thought. I'm not sure it would affect the solar panels so much though.
Judging by the amount of snow in the gutter it would appear that the snow if falling off rather than thawing - although a mild thawing could be causing the fall.
It is good on here to get feedback from customers, if we like it or not we can all learn from them, at the end of the day, we work on there behalf, and without them we would not have an industry..
Please carry on with your posting.
Yes, It's amazing how much heat is lost through a badly insulated roof though, they could have insulation removed to accommodate the fashion for down lighters, coupled with the heating being on full tilt in the cold weather. The edge of the house may not be affected by down light holes Could speculate all day lol.
Both houses are identical twins, side-by-side in the same orientation. There's no shading at all - just a big open field to the SouthEast; nothing between the PV arrays and the sun. No buildings, no telephone wires.
In pic 3 there is a house next to it, as the sun rises in the east and is low in the sky maybe a little shade early on.
Sorry, it was just a thought.
Guess it is just a mystery of life, like why did kamikaze pilots where crash helmets?
Can you tell the panel brands or if they are monos or polys?
In the next several days I will try to get all the details (panel type, schematics, inverter etc) and add them to this topic. I haven't had much chance to speak to the neighbours for a few months. I strongly suspect that the neighbours' 18x200W(ish) array is "rent-a-roof".
The 15x250W panels are Chinese-built mono.
The 18x200W (ish) panels look like mono (there's no "cracked" look to the cells) but the light is fading now and they might be poly; the 18x200W panels are noticably blue-tinted in comparison to the 15x250W array, as you can see in the pictures above.
Sorry that I can't provide more details at the moment, but nevertheless, there might be something going on which others can look out for on other arrays around the country - and it could turn out to be of value in areas where snow is a problem.
At the moment, I have several wild guesses in my head:
1. The bigger panels cause the snow to lay in a more fragile way (like a long piece of plywood gives way more easily than a smaller piece).
2. The bigger panels might have a smaller rim around the edge, so snow slides off easier.
3. The bigger panels might have slightly wider "ventilation" spacing which helps snow fall off.
4. The layout of the string(s) and/or bypass diodes could be affecting heat accumulation/disipation.
5. The panels have different coatings on the glass.
6. A flock of birds landed on the 15x250 array and dislodged the snow. Given the way the snow remains on the middle panels though, I can't see this as being the cause but you never know.
I have an observation...... Oh the joy to to have such straightforward roofs to install pv as those!!!!!!
Unlike this one near me, roof facing due East!
There's another panel out of view behind the small gable!
Absolutely. I have been trying to figure out how to fit 2 rows of 250w panels on a roof 5.8 x 3.2 to make 3kw. Apparently another company can.
Could it be because the one on the left started feed in.
My panels were covered in snow about 10mm this morning and the inverter started feed in. When I left if was producing 150w and looked like it was starting to melt.
That would mean quite a difference in performance, considering that the two arrays "on paper" are very similar.
When the picture was taken (about 9.45-10am), the inverter for my array (the 15x250W) was outputting at a rate of about 1.8kWh per hour, compared to usually putting out about 2.2kWh per hour in similar sunlight conditions recently when there wasn't snow partially obscuring the panels.
It had been generating at about 0.5kWh per hour when I crawled out of bed around 8.30am this morning (suffering from man-Flu).
With two panels completely covered with snow and with six other panels slightly impaired (let's say equal to one more panel of complete obstruction), that's only 12/15panels (80%) of the area functional, yet the system was generating 1.8/2.2kW (82%) of the output that would have been achieved without snow.
So the loss of output from shaded/snowed-in panels - even considering the strings and the active bypass circuits on the panels - seems to not be nearly as bad an effect on other panels in the same string as many people suggest.
I've seen hot spots on my own Kioto modules, which is strange as they're supposed to have anti-hotspot technology. Anyway the modules showing heated cells clear quicker than the others.
it's not to do with insulation or the temperature in the house as the amount of snow on each roof is about the same. The most likely explanation is that good quality panels come with a hydrophobic coating on. this gives the panels a degree of self cleaning ability which will also reduce the adhesive force between the snow and the panel. Cheap panels either have no coating or an inferior coating. After several years in the optical industry I have seen good quality coatings and bad ones (from the opticians you shouldn't have gone to mostly!) and there is a considerable difference between the two. A good quality coating requires a high level of technical expertise and expensive equipment.
This is one of the things you pay for on a better quality panel
of course I may have my humble pie with ice cream if they turn out to be the same make of panel but thats my view of it.
The house on the left could have Suntech 250W hydrophobic coated solar panels, where as the one on the right doesnt.
Either that or Santa polished the panels on the left with Pledge, because he had no chimney to climb down, whereas the house on the right has a tight chimney and he probably ran out of time, trying to squeeze himself down on his alloted delivery slot :)
They look like my suntech panels. Mine didn't clear like that, I had a day of zero output. But my roof isn't quite as steep. But the snow did slide off by the next day.
What would be interesting is knowing the generating figs for both systems at this point in time.... this may also indicate or give you better info for clearer assumption to be made as to what is really going on here and why one system is cleared of snow and the other not, up and above other contributing factors like better loft isolation, heating on higher etc etc
I have noticed myself that my Sanyo HITs clear snow very well and very quickly and have never really have any snow on them when running even at low output............
EDIT:- Also when water runs off them it seems to act exactly the same as on a well WAXED car
OP, Can we safety assume the house on the right is even switched on and working, hence why I asked earlier comparison of figs at this exact point would be so interesting ??
Also knowing exactly the setup next door would be so helpful, which and how many inverters used, how many strings, panel voltages, startup voltages of inverter(s) etc etc
It seems you could learn alot from this initial observation........ and for good reading here - LOL
Sanyo, being a good quality panel have a good quality coating. the effect described above of water blobbing up is characteristic of a good hydrophobic coating, where the cohesive forces of the water are greater than the adhesive forces of the surface/water interface.
It's a difficult thing to prove but this would suggest an improved performance on quality panels which doesn't appear in the performance figures as they will self clean better and clear better in the rain. It's these unmeasured aspects of quality panels that mark the difference in the real world.
Yes, I will definitely speak to the neighbour to find out what is fitted and report back here.
Their system is fully operational as far as I know - there hasn't been anyone come back since the panels were fitted a few months ago. I would be very likely to know if someone had been back as I work from home nowadays and we have a narrow, shared driveway.
I was reluctant to post my system details until the neighbours details were also known, to allow a fair comparison and avoid any prejudice. But to avoid keeping people in suspense.....
The apparently "hydrophobic" system on the left is mine and is as follows:
40 degree roof pitch, facing SouthEast, large open field out the back of the house (no shading from trees/pylons/telephone wires), located in East Anglia.
Kinve 250W mono panels.
Two strings (8+7 panels).
Cables go into loft through the tiles, then across to the side of the loft and down the side of the house, to the inverter which is fitted in a downstairs utility room on the other side (front) of the house (cold North corner; the small amount of extra heat from the inverter's activity doesn't go to waste!).
The two panel strings have separate DC isolators adjacent to the inverter, each feeding into one of its dual MPPT. Total length of DC cables is about 15metres from panels to DC isolator. DC cable is ~5mm outer diameter, ~2mm core.
Inverter is Aurora 3600.
AC isolator is adjacent to inverter and AC cable then runs a couple of metres to the fusebox and electricity meter by the front door.
The system is performing roughy as expected for this time of year, but hasn't yet seen a summer, so the jury is still out on how well it works overall.
Panel voltages:
Voc: 37.3
Vmp: 30.1
Isc: 8.78
Imp: 8.31
Array/string voltages:
Voc1: 298
Voc2: 261
Vmp1: 241
Vmp2: 211
Inverter:
Minimum voltage to connect to grid: 200
MPPT voltage operating range: 90 to 580
Full power voltage operating range: 200 to 530
Picture of my inverter and its associated input/output cables, in the downstairs utility room.
Aurora 3600 inverter with the two grey DC isolators (one for each PV array) to the left, and yellow AC isolator to the right, with cable in trunking going up to the fuse box.
The panels on the left house look to have a slight gap around each panel - the one's on the right are butted up together (I think). Could it be that the gap weakens the grip of the snow, letting each panel shed it's load sooner?
Probably a red hearing.
Just been out to look and I think the size of the gap around each panel is just a camera/perspective thing.
Still no chance to speak to the neighbours yet regarding the type of panel fitted.
Interesting Observation...
FB.,
FB.,
