Interesting three way conversion to two way and swap for time lag. | Page 4 | on ElectriciansForums
Discuss Interesting three way conversion to two way and swap for time lag. in the UK Electrical Forum area at ElectriciansForums.net
T
The Ghost
If your bored or like a challenge I thought (maybe wrongly) this might be interesting to trainees and maybe others. As the title convert three way switching to two way (Sw 2 + 3) [ElectriciansForums.net] Interesting three way conversion to two way and swap for time lag.
danlers time lag (Master and slave) using switch 2 and 3. Assume you cannot find the junction box. Can it be done? Note we have L in at switch 1, no accessible switch return. I included a couple of photos to give the ---- drawing some context. The switch return (green) is pure conjecture on my part, but it must be something along those lines. There is no switch return wire at any switch.
How are we supposed to know where it goes? For all we know it goes to feed another switch/light. The way I see it is with the limited description of how it's connected and an educated guess you don't have enough cores to wire it as master and Slave but standard time lag switches would be the sensible thing to of installed as it would of been as simple as connecting the Lines and switch lines in parralel across th switches. You say you've got it working master and slave...did you have a magic wand or are we missing the obvious? From your posts I gather it's something to do with the red with the question mark in your diagram? I don't know how we are expected to have a scooby doo where it goes?
Ok just to stop all speculation I installed sensor lights and arranged a permanent live and blanked off all switches. Sorry if you found this frustrating. As I intimated you would get to the point that it can't be done as you do not have enough cables and you would have to think of something else. I did not want to say this as I thought maybe some trainees would try to work it out. But there you go. Oh and I did not say I got it working with master and slave. I just said I got it working and thought outside the box. I was trying not to say what I did do. Anyway there is no way to get the live up to sw. 2 and 3 with returns for both as there are not enough cables. Hence screw all the above just fit sensors. Unless you want to go and find the mythical junction box which believe me you would not want to given the possible location and circumstances.
You could of just used standard time lag switches and got it working.
Yes I agree you could get it working but that would be based on the premise that the yellow is the sw. return. Logic says it is but empirical evidence does not confirm that so bang test it is then and who cares where the red cable goes from sw. 1 common. (Joking!)
Reply to Interesting three way conversion to two way and swap for time lag. in the UK Electrical Forum area at ElectriciansForums.net
