Intermediate switch first in 3 way? | on ElectriciansForums
Discuss Intermediate switch first in 3 way? in the UK Electrical Forum area at ElectriciansForums.net
Capra
Chester
So.. we've dropped a clanger.
3 way switching for large Hallway.
Switch wire drops to 1 gang switch(2way), then 3-core to 4-gang switch, then 3-core to 1-gang(2way). This means our 2nd switch isn't an intermediate - but a 2-way.
(Not aware of anyone who makes a 4-gang switch with an intermediate module - which would sort this straight away)
Just wondering if anyone has an ideas of how we can get this to function - other than removing a module from an intermediate and getting it to work in our 4-gang.
Is there any method in which the intermediate switch can used as the first switch in the group? I can't think of one... but i know there's some clever folks on here.........
Never knew there was a place you could build your own light switch..... where's the world heading!
Grid is looking like the obvious fix.... maybe she won't notice.... ;)
If you use the click mode range that's been referred to a few times throughout the thread then they look like normal switch plates as they dont have yokes etc. If you went and brought a 4gang click mode switch....the switch is a 4module aperture plate with 4 module switches.
I wanted to keep the plates the same, as the customer hoped. Hence the the original post asking if anyone had any method of using 3-way switching with the inter switch first. I didn't think it was possible - but things are always worth asking about.
Other option was to take a intermediate module out of a 1 gang intermediate switch, from the same range as the 4 gang - and fit it in the 4 gang. It's doesn't just "fit" - as i've looked. Then again - it's not a modular system that's designed to be swapped - so I wouldn't expect it to.
In fairness.. the customer might not even have said out if I'd just used a grid.. but when I told her about our cock up, I got "oooh i really want them all exactly the same" So I thought I'd look at options to appease. You know how it is.
I've never used click mode before - only MK.
Reply to Intermediate switch first in 3 way? in the UK Electrical Forum area at ElectriciansForums.net
The old thread, that our friend hijacked, is here 2 dimmers on 2 way switching -...
Yes I understand the setup now. Sorry about my confusing first post 🫢 It might be worth buying the Livolo switches you identified and lash at...
