Intermediate switch | on ElectriciansForums
Discuss Intermediate switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Delboy247
Help needed with this dilemma I can't get an intermediate circuit to switch correctly right this is why
I have got three switches 2 two ways and one intermediate 3 core cable is run from each of the two way switches to the intermediate switch where also the twin and earth from the light fitting there aswell acting as a switch line any help would be great thanks in advance.
Hi
When you say the T&E from the light is at the intermediate also, is it the switch feed & switch wire down from the light or, is it meant to be the switched line & neutral up to the light???
Hi Lenny yeah switch line and feed I've tried every combo I'm sure I have, the client is looking at me weird iv managed to blag it saying it's the switch and I will be returning next week with a new one
The only way of getting it to work is to create a conventional 2 way switching method.
At the intermediate put the switch feed in a connector with the 'spare' core of one of the 3 cores, and put the switch wire in a connector with the other 'spare' core of the other 3 core.
What you should then have is a permanent live connected to the common of one of the 2 way switches, and a switched live connected to the common at the other 2 way.
This is the 'old' 2 way method of switching and is the way singles in conduit 2 ways are usually done, although the permanent live and switched live are taken directly to the end 2 ways not via the intermediate.
Yup, you wire the switch wire across the strappers, just as you would in a 2 way switch.
Remember, your strappers should be opposite each other in the terminals with the common crimped.
I remember the first time I came across this set up was in a hostel, and if my memory serves me correctly i think it was 6 or 7 way, i was buggered! Got it in the end though after lots of head scratching:cool:
if i read your post right, i would crimp connect the blacks (commons on the 2 way switches). strappers in to the intermediate switch, and then the L and S/L from the fitting in with one pair of the strappers.
Just wire your two-ways with the three core (c-c, l1-l1,l2-l2).
Fit intermediate, as you would, between the strappers. (common in connector block)
Connect live & switch live to one side of the intermediate (doesn't matter which.)
Job done.:)
Reply to Intermediate switch in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
The old thread, that our friend hijacked, is here 2 dimmers on 2 way switching -...
How has this been wired, do you have the supply at one two way and the cable to the light at the other two way with cables from the intermediate...
