kreatiff63
I'm using the power to switch method for three kitchen pendant lights that have 3 switches with 1 intermediate. I'm using 3 Core for the switching cables and 2 Core to the lights. The problem I'm having is that the lights aren't coming on, so I need to go through the some checking of the connections, and measuring of power at the light and source.
I'm taking the source power from a neighbouring switch that works. I'm taking the neutral from the neighbouring light too and extending that to the first light, and then the following two lights. I'm using 3core between the switches, as shown in the diagram below, and 2 core to the lights. The earth is carried through the lights using 3 way connectors. I was struggling with connecting these with the covering yellow/green into a terminal.
Lighting diagram...
Lighting diagram...
