intermittent domestic lighting fault | on ElectriciansForums
Discuss intermittent domestic lighting fault in the Domestic Electrician Forum area at ElectriciansForums.net
alan-c
south east
I was going to post this in DIY but it appears locked for some reason, so here we are.
Downstairs bathroom light flickered and went out, the three fittings on this spur are now not working. (Due to various building works, three lights are on a spur from the garage ring, which is itself an extension of the kitchen ring). This happened once before, but removing then replacing the 5A fuse in the spur "seemed" to fix it, but not this time. I suspected a loose wire and have checked every reachable connector but can't find any loose connections. But on checking the 5A switched fusebox with a Fluke dvm I find 240v to the spur, and something strange on the isolated section - 95k ohms rising slowly to about 120k ohms while watching for half a minute. This is too high to be bulb resistance with a fitting switched on and much too low, I believe, to be insulation resistance.
I'll have to call out a Proper Bloke but does anyone have any suggestions? the fuse is still fine.
100k ohms is low for insulation resistance, but the circuit will still be functional at that level. You might get odd (L to N) resistance values if the bulbs are compact fluorescent or LED. However, I doubt if poor insulation resistance is relevant to your fault.
Where in the south east are you?
Sorry about the late reply to your suggestions.
Handysparks - there are LED lamps in the bathroom fitting so I suppose the strange measurement could be due to that.
Murdoch - I don't know how to test the continuity of each core; this post was supposed to be in DIY!
I've arranged for an electrician who will come tomorrow, I'll post the outcome here.
Just out of interest, but I don't think it's relevant, the CU fitted a year ago to replace old fuseboxes has been wrongly labeled. "kitchen sockets" and "downstairs sockets" MCB's are swapped. I suppose I should get the original contractor back to correct this as it is documented. Any comments welcome.
Sorted.
Electrician (a friend of my son) came round and almost immediately found a cracked live conductor at the start of the spur; it broke as he moved it.
He thought that the resistance I measured was probably LED lights.
Thanks for your replies,
Alan-c
Reply to intermittent domestic lighting fault in the Domestic Electrician Forum area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
