Intermittent hazard lights | on ElectriciansForums
Discuss Intermittent hazard lights in the Auto Electrician Forum area at ElectriciansForums.net
Florida
Greetings.
I'm having problems with the hazard lights in my 1999 chevy Blazer. It works as expected for some time with both sides blinking and then, suddenly, all four turning signal lights stop flashing and keep lit. If I keep pressing the hazard button multiple times they get "unstuck" for some time but not for too long.
Something I've observed is that when I'm driving on very irregular dirt roads the turn signal indicator on the dashboard blinks randomly, which makes me believe that the problem might be some broken wire insulation somewhere. Could this be the problem cause?
I've checked all fuses and they are all ok. Also, I've replaced the turn signal relay but nothing changed.
Reply to Intermittent hazard lights in the Auto Electrician Forum area at ElectriciansForums.net
Thanks a lot FG; Thanks for that solution, I was looking along the same direction and yesterday ordered two 5 pin 12v 40A relays from Amazon and...
Hi Did you fix your lights? Would love to see a photo of your bike!
