C
CraigJTD
Hello there i wonder if anyone could offer any advice on a problem I am having:
Although not a qualified electrician, I recently swapped out the old Wylex re-wireable fuse board in my house and replaced it with a split load dual rcd board. Before anyone tells me off, I am not a complete novice and trained as an electrician for three years before dropping out with one month left to qualify (a long story).
Anyway since the recent switch I have been having problems with the downstairs lighting circuit. One particular circuit, the wall lights downstairs, trips the RCD as soon as it is turned on. Once the lights are turned off the RCD will reset no problem.
As I am little rusty on the testing side of things I drafted in one of the lads who is a qualified electrician. He has since been around to carry out some tests, to check for borrowed nuetrals, L-E faults, L - N Faults etc had has come up with a blank. If it is of any help it was a Metrell all in one tester that he used.
We have tried removing all the bulbs and just putting one in each fitting in turn (there are 4) to try narrow it down to one particular fitting but it trips on every one.
This was two weeks ago, my mate is very busy at present with getting his house sorted for the imminenant arrival of his first baby so he is hard to pin down.
In the meantime I just thought I would do some digging to see if I could come up with anything.
Since taking all the bulbs out of said cicuit I have had 2 subsequent trips, which is now making me lean towards thinking that it may be realted to something other.
Any ideas/suggestions as to cause or tests that would help identify would be greatly appreciated, I am beginning to wish I had just left the old board in!
Thanks in adavance
Craig
Thanks in adavance
Craig
