Intermittent wiper switch for classic car | on ElectriciansForums
Discuss Intermittent wiper switch for classic car in the Auto Electrician Forum area at ElectriciansForums.net
Wiltshire
My old classic only has a one-speed wiper. I really would like to fit an intermittent device so that I can vary the time between wipes. I am fed up with reaching for the wiper switch when there is only very light rainfall.
Whilst at a steam rally recently, I picked up an old wiper dwell switch with a variable dial on the front and I wonder if that will do the job. It has three wires....red, green and black.
I attach a wiring diagram of the present arrangement. There are three wires...green, black and black/green. I would be grateful if somebody would help me with the proper connections.
[ElectriciansForums.net] Intermittent wiper switch for classic car
Hi: On your diagram, where does the green wire to your wiper motor go ?
On your dwell pot I would imagine that the Red is +12v supply, Black is your Negative connection and Green is the variable output to your wiper motor. You need to check this though.
If the Green is permanent +12v then in theory that would be removed from the motor & go to Red on the Dwell pot, Black would go to the wiper motor side of the wiper switch & Green would go to the wiper motor.
In theory that would give you on / off as normal and variable speed through the pot on the PCB.
As you said, you could check wiring & operation with a battery and bulb or 12v test lamp.
Reply to Intermittent wiper switch for classic car in the Auto Electrician Forum area at ElectriciansForums.net
Everything worked perfectly—thank you so much for your guidance! I followed your advice and isolated the supply permanent live in the Wago...
Firstly I would suggest that of the three sets of cables, they are not all 'incoming'. There might be one cable (of 3 wires) bringing in permanent...
