Internal to External PVC Conduit | on ElectriciansForums
Discuss Internal to External PVC Conduit in the UK Electrical Forum area at ElectriciansForums.net
J
Jamesj
Hi all,
Some help is required, I am currently trying to run network + 12v cable out to my dog kennels (for cctv cameras) and have a slight problem working out how the conduit should be installed correctly. The run is only short but the cables must exit mid way up and in the middle of an external wall, immediately make a 90 degree turn downwards to a junction box (needs to be waterproof) and then round an inside corner and into the kennels.
I'm ok with all of this except two things, firstly all the pvc conduit and junction boxes I see on the internet 'look' like they're waterproof but don't seem to have an IP rating, are PVC conduit/junction boxes/connecting glands IP rated?? Secondly and the biggest problem I'm having is how should the conduit exit the building?? In the good old U S of A they seem to have a fitting just for this (an LB fitting) but I can't find anything similar in the UK, does it exist??? If not what is the correct/acceptable method of doing this.
Links to obvious solutions that I'm stupidly missing are very welcome :)
Thanks in advance!
Any possibility of bringing the conduit through the wall and straight into the back of the box. If you make it a snug fit, you can glue the end of the conduit into the box with the adhesive used for plumbing fittings or the PVC adhesive sold for conduit. You can also use this stuff for gluing conduit into fittings. You may run into trouble if the runs are long as there'll be no possibility of movement to allow for expansion in the heat.
Can I just add to that adhesive wouldnt be required if he put an adaptor on the end then into the box...
Terminate the conduit into the back of a 4x4 IP56 weatherproof box.
And drill a 4mm drain hole in the bottom rear corner of any box or fitting where condensation can collect. It sounds wrong drilling holes in weatherproof boxes, but you'll find a specific drain hole position in most plastic adaptable boxes. And do the same for the lower most part of any conduit run unless it can drain into a box which itself has a drain hole.
The conduit boxes themselves won't have an IP rating because the bits generally come separately, and depend on how you seal them, ie with glue/cement. For a weatherproof box you'll need a rubber gasket.
Reply to Internal to External PVC Conduit in the UK Electrical Forum area at ElectriciansForums.net
If you get a length of conduit, and seal both ends then the IP rating will instantly be IP68!! If you buy an IP66 rated Wiska box it will...
