Internal wall insulation- help!! | on ElectriciansForums
Discuss Internal wall insulation- help!! in the UK Electrical Forum area at ElectriciansForums.net
notts
Hi all.
I am required to do a complete rewire on a 1920s terrace property with 9" solid brick walls which is then to be replastered using 30mm wallboards dot and dabbed to the brick- that is 18mm insulation backed onto a 12mm plasterboard.
Sure many of you have done this many times so my question may have an easy answer.
Do I surface mount the cables to the brick cutting the insulation off of the board in a channel around the cables and call it clipped direct? Don't really want to be uprating cable sizes and then derating them for insulation!
Obviously there is a direct conflict between keeping the walls warm and the cables cool!
Any advice would be appreciated immensely as the reference methods in the regs do not appear to cover this situation definitively.
Many thanks in advance
I would clip the cables to the wall and the thickness of the dab will mean you shouldn't have to cut away any of the insulation. You shouldn't need to de-rate the cables as the coolness of the brickwork and the airspace around the dabs will allow sufficient cooling.
Someone will be along shortly to disagree with me though!
hate capping. nails either bend on hard mortar or fall out of soft. drill and plug oval tube clips for me every time.
Would there still be room for the boards to go over though Tel? The oval tubing is going to stick out more than capping.
Ive never come across dot and dab for insulation backed plasterboard.
Will the adhesive stick to the foil?
Electrically as above no different to any other D&D plasterboard.
Reply to Internal wall insulation- help!! in the UK Electrical Forum area at ElectriciansForums.net
