Intex Inflatable Hot Hub Usage | Page 2 | on ElectriciansForums
Discuss Intex Inflatable Hot Hub Usage in the UK Electrical Forum area at ElectriciansForums.net
NA Radium
Leicestershire
Hi all,
I am new to this forum so please bear with me. I am seeking advise on the do's and don't in regards to using an inflatable hot tub.
Please be aware that my options are somewhat limited as I am a private tenant.
The hot tub has its own in-line RCD rated for 16Amps and the manual states it draws 13Amps as a minimum!
I have checked the circuits and we have upstairs and downstairs sockets on separate circuits rated at 32Amps.
The complication I have is I don't think the lead from the pump will be long enough to reach to the nearest socket in the conservatory, could we get away with using a heavy duty extension lead?
Edit:
I have found a digital copy of the manual should it be useful and it mentions extensions leads should not be used :confused:. Also I believe the cable from the pump is between 3-4 meters long.
[automerge]1585687931[/automerge]
  • [ElectriciansForums.net] Intex Inflatable Hot Hub Usage
So is the OP buys a 2 meter extension lead that can take 13A (or make one himself) and get a waterproof cover for the extension lead connection outside then what is the problem?
I'm presuming his DB will have an RCD so that will cover the extension lead, if not then just change a the socket he is using to a RCD one.
I have been in touch with the people suggested in a previous reply, and have been advised to buy the following extension lead; specifically the 2.5mm csa cable. This would make the total length of cable 15 meters including the cable from the hot tub.
In addition to this I would also buy the Dry box.
As the cable from the hot tub has an inline PRCD do I need to consider one from the wall (a plug in one) for the extension lead?
[automerge]1585759049[/automerge]
I have just check the DB and it has an RCD covering the all of the sockets in the household.
you may well find that the tub RCD is a 10mA.
Reply to Intex Inflatable Hot Hub Usage in the UK Electrical Forum area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
