Inverter and Battery Combo | on ElectriciansForums
Discuss Inverter and Battery Combo in the UK Electrical Forum area at ElectriciansForums.net
Mr.Si
Lancing, West Sussex
Hi all,
Long time.
I was wondering if anyone on here knows of any combo unit that is an inverter from 12v - 230v that is rated at 600W continuous BUT has a battery attached as part of it.
I suspect such a thing doesn't exist at this rating having done some searching already as you'd need a battery with around 55Ah if it's to be able to work for an hour at that power draw and you'd then be in to a heavy weight unit, but I thought I'd ask anyway.
Cheers,
Simon
Hi all,
Long time.
Cheers,
Simon
i think you can get them mate after all a ups bassically contains an inverter (12v battery inside)
You can get 3kW ones, that I do know, as tour busses have loads of them in!
- edit -
Just re-read your OP - you mean as in 'one box' with it all in? Hmmm.....that might be a stretch! A UPS unit of that size normally only powers for so long whilst the software shuts the servers off cleanly etc, not an indefinite power source.
What's the reason / application for needing a combo unit?
Reply to Inverter and Battery Combo in the UK Electrical Forum area at ElectriciansForums.net
Received guidance from a logical soul on the Kawie Riders forum: Acc Fuse Block Power to BAT LOAD, install new cable from BAT LINE to AUX + (and)...
Inverter leads do tend to be quite meaty. An extension cord won't survive I wouldnt have thought
