Inverter ballast help!! | on ElectriciansForums
Discuss Inverter ballast help!! in the Australia area at ElectriciansForums.net
A
Adam Smith
Good evening all,
Has anyone had experiences with installing inverter ballasts?
I am trying to install an Orbik pvr50 ballast in a flory so it will run off a 50v UPS system in the event of power loss. I rewired the unit to the wiring diagram but im not getting any power going through the circuit. I have feed directly into 'switched live in' but am not getting a feed coming from 'switched live out'. I have tried 2 different inverter ballasts but no joy!
The flory has a Tridonic electronic ballast btw.
Could anyone recommend somewhere online that could shed some light on the matter?
Cheers
Reply to Inverter ballast help!! in the Australia area at ElectriciansForums.net
Hi all, I've been at this all night for a smart switch I've installed for exterior lighting for the house located in the eve's of the house attic...
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
