Inverter location | on ElectriciansForums
Discuss Inverter location in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
digital48
Does an inverter need to be close to the consumer unit and does it have to actually connect into the CU? I'm hoping to install it in the garage to avoid a very hot loft, but the CU is inside the house in a fairly inaccessible location whilst the meter and company fuse are on the garage wall. Could the connection be made close to the meter?
Install an additional consumer unit dedicated to the PV adjacent to the main incoming fuse cut-out. Don't forget to install a 100A 2 pole isolator that can isolate both the existing DB & the new one. MEM do a unit with a BS88 80A fuse built in which is compact & accepts 25mm double insulated tails.
Thanks for the reply: it was what I was hoping for, but I'm not sure what DB refers to.
Guys, this is the problem that the Solar PV installation business is facing. If you look at the quality of questions being asked over the last 9 months they have been getting steadily more basic and gives cause for concen about the level of competence of individual installers.
Perhaps there should be a Master Guild of PV Installers!
Perhaps 'someone' has been jumping to conclusions?
Perhaps 'someone' has assumed that I'm an installer?
Perhaps I'm simply interested in the subject and looking to understand it better?
In which case my apologies digital48
Any good installer can easily answer these questions for you and can advise on your particluar instance what is the best for you (and I mean for you) they cannot do it without a site visit, as it also depends upon cable routings, connection details etc.
Find a good local MCS certified installer that doesn't hesitate when you ask for references, and they can answer your specifics.
The best option (for you) is not always the cheapest.
Seeing as you like direct questions, without explanation here are your direct answers:
Does an inverter need to be close to the consumer unit?
NO
Does it have to actually connect into the CU?
NO
YES
However wether that is how it should be done in your case is a completely different matter.
No need. I think you'll find that the number of posters in my position will increase as we come across more and more installers who don't know what they're talking about. I've had several quotes and any number of them have contradicted each other or given information that was simply wrong (including from the rep of an installer who got national, and seeming positive) exposure on TV a few weeks ago). How do I know? From reading and asking on forums such as this.
See above! You only know if they're good if you have a little knowledge yourself or if they come well recommended by someone who has got an installation which is more than a few weeks old. The Solar PV industry, from a consumer's point of view, has all the hallmarks of the worst of the double glazing industry a few years ago: the good guys in danger of being swamped by unscrupulous cowboys.
Agreed, and I won't be going with the cheapest, though the cheapest, to date, has come in at two thirds of the dearest (which magically dropped by ÂŁ1500 within 10 days once he became aware).
NO
NO
YES
No! The explanations are the most important part of the answer. That's where the understanding comes from. The explanation I got on whether or not the connection had to be into the existing CU was excellent. I simply didn't (and still don't) know what DB stood for. I do know now, however, that if I get an installer telling me he's got to go to the CU I can suggest otherwise with some confidence (to get to the CU is going to be seriously messy as it's pretty much buried in the centre of the house).
Agreed.
And thanks for your response!
I strongly agree.
By making MCS a paperwork exercise that can be pretty much bought, it was bound to happen. I'm happy to answer questions on here but some of the questions being asked are so basic that you can clearly see that some of the installers are way out of their depth.
There also seems to be a lot more shoddy installs going up. Some of the things I've been seeing have really angered me and I am really tempted to knock on doors and ask the home owner exactly what is going on.
No need. I think you'll find that the number of posters in my position will increase as we come across more and more installers who don't know what they're talking about. I've had several quotes and any number of them have contradicted each other or given information that was simply wrong (including from the rep of an installer who got national, and seeming positive) exposure on TV a few weeks ago). How do I know? From reading and asking on forums such as this.!
This is one of the best things about this forum. Joe Public can come on and read for themselves. This way it helps them distinguish between the crap installers and the decent installers.
Exactly! And from what I've read on here, and other similar forums, I've binned two quotes and asked one of the others to reconsider one of the options he had offered. I even got the two I eventually binned to come back and have another look just to check I'd not misunderstood. I hadn't, they were binned...
Two of the other quotes I got were from posters on one of the forums. They clearly knew what they were talking about and their answers to questions from Joe Public (AKA 'Potential Clients') inspired confidence.
Reply to Inverter location in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
We had a similar call out and the issue was with the grid (which they admitted). Voltage was too high.
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
