Inverter Mounting Solution Needed... | on ElectriciansForums
Discuss Inverter Mounting Solution Needed... in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
F
FIT-PV
We are in the middle of doing a commercial project, and have 5 Mastervolt TL Inverters that weigh about 60KG each. Ideally these should be wall mounted.
However, as it goes in the construction business, our requirements have been ignored, and the space that was required for us has not been given. Therefore a solid wall mounting solution is no longer an option for us.
Has anyone used any sort of special A-Frames or mounting solutions other than a wall mount for an inverter. (Inverters to be located in doors)
Youll have to look at the mounting instructions as some inverters dont like being orientated too much off verticle. Why not use the sectional "scaffold" style barrier system to manufacture a pole mount framework for the inverters, the feet bolt into concrete.
A lot of the commercial ones I've seen are mounted on Unistrut frames, either tethered to a soild structure or freestanding.
Will this photo do you? partition (studding wall on one side!) - Long live Unistrut [ElectriciansForums.net] Inverter Mounting Solution Needed...
Excellent Guys... Many thanks. A colleague also suggested custom built A Frames, but I think this solution looks good.
Reply to Inverter Mounting Solution Needed... in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
