Inverters with 700kVa BGG generators | on ElectriciansForums
Discuss Inverters with 700kVa BGG generators in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Mark.W
Swindon, Wilts
Morning guys
Quick question, I've got 2 SMA 15000 TL's fed from a schneider P-Bloc Plus panel, on the same busbar we have 2 700kVa generators which run for about 120 hrs a year and only come on when the grid needs it. My question is when those generators come on will they damage the inverters or should I install a contactor in line with the PV?
Many thanks
Mark
Reply to Inverters with 700kVa BGG generators in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
A picture paints a thousand words so here's an SLD showing my installation and some annotations to show the proposed relocation of the DC...
