Hi all, little bit of a brain teaser.
We installed 5 IP dome Camera's(Onyx i believe is the make) to a DVR(Which receives the data and records it) QVIS izeus 4000 if that'll help. We have three working and the other two aren't; They're connected via CAT 5 and RJ45 connectors with each having their own port with PoE(Power over Ethernet).
The two that don't work are the furthest from the DVR by around 30-35 metres. at first we suspected damaged cable so we re-ran it. Nothing. we then realised it was CCA Cable (Copper Coated Aluminium) which is only good for around 30/35 metres so we suspected the volt drop would too high for them to actually power the cameras. We rewired them again using solid copper wire (Which is good for around 100Metres) yet still no success.
A couple of options would be to move the DVR closer to the load(Which would be impractical since it's wired through 20mm conduit and it's all set up) or move the cameras closer to the DVR which again can't really be done since the customer wouldn't be able to monitor where he wanted to. I rang Paul with his infinite wisdom hoping he could solve it, he suggested to double the power cable to those cameras with any spare pins however I later found out there's not any spare pins:
So we were going to try a light transformer (230V AC to 12V DC) but turns out the transformers convert it into 11.8V AC(We'll be trying again with the right transformer when we're back at the job i think) and testing what the volt drop actually is at the camera point.
It's wired in 20mm conduit, There's no LV cables anywhere near the CAT5 cables, the cameras are proved; we took them down and tried them using a short Ethernet cable. The cable has continuity throughout and the manufacturer did all the port forwarding to get it to be able to be viewed with the IP address etc.
Wondering if anyone came across this before or just wants to have a go at finding a solution... I was going to post this when we figured out the problem. Can't wait to hear some of your ideas.
