IP rated bathroom lamp - like standard pendant | on ElectriciansForums
Discuss IP rated bathroom lamp - like standard pendant in the Electrical Tools and Products area at ElectriciansForums.net
M
martom
Hi, maybe somebody came across bathroom lights they are similar to standard pendants? My customer wants me to supply and fit bathroom lamp which should look as close as a standard 6inch light pendant. Couldn't find nowhere.
Tom
Well dependant where in the bathroom you are fitting it you could fit a standard pendant. Look in your onsite-guide at the bathroom zones.
You are not going to find an IP rated pendant as if they are IP44 rated then they have to be enclosed and a pendant is not enclosed, they are mutually exclusive.
You could have an enclosed pendant
[ElectriciansForums.net] IP rated bathroom lamp - like standard pendant
or go for a fixed ball
or a single spotlight perhaps, but none of them very pendant like.
I think you will be out of luck trying to get some sort of standard pendant fitting,you may have to get a specific fancy fitting designed for a Bathroom
There used to be a pendant that was fitted sometimes in a Bathroom,it had a sealed entry for the flex, a stuffing gland type entry,then a Home office skirt on the lamp holder
Reply to IP rated bathroom lamp - like standard pendant in the Electrical Tools and Products area at ElectriciansForums.net
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
