shiva67
Could any one let me know what code to issue for a fitting which is not IP rated,
Discuss Ip rated fittings in the bathroom in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
P.S Is it true that as from next year the Periodic is changing, as in the codes and insperction ????
Sav
Yes.....the Periodic will be killed off......but fear not, it will regenerate into the Installation Condition Report.
Bit like the RCD isnt it ,people sell you an RCD for your lawn mower hedge trimmers strimmers why cause they wont work if you cut the cable because they are two core and no earth !!!
When you cut the cable,you are dead shorting the live and neutral
The rcd will not recognise this because balance is maintained
The overcurrent device will protect this type of situation
If a person touches a live conductor of an extension lead or mower and conducts part of the current to earth through themselves, an imbalance will occur and will be sensed by the Rcd,no earth is required,you are the path and you are protected without an earth present
Reply to Ip rated fittings in the bathroom in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
