tomodo
Hi all, if you have a consumer unit with holes in the top bigger than 1mm but it is butted up against the ceiling is this acceptable? as it is not readily accessible? but technically would be if you lifted upstairs floorboards?
Discuss Ip rating top of consumer unit in the UK Electrical Forum area at ElectriciansForums.net
The CU needs to have an appropriate IP Code to meet the requirements of BS 7671.Hi all, if you have a consumer unit with holes in the top bigger than 1mm but it is butted up against the ceiling is this acceptable? as it is not readily accessible? but technically would be if you lifted upstairs floorboards?
Reply to Ip rating top of consumer unit in the UK Electrical Forum area at ElectriciansForums.net
