B
bigd
I'm fitting a 100mA RCD to a TT system (domestic) to comply with the regs. Is it acceptable to fit a 100mA RCD as a main switch in a CU?
The original set-up was a stand alone mini CU with a 100mA RCD which in turn fed the main CU. The problem being maintaining the IP4X top surface rating on the stand alone 100mA RCD
Dave
Dave
