IP66 Enclosures - how low can they go? | on ElectriciansForums
Discuss IP66 Enclosures - how low can they go? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
L
leolec
Given the table below, how close to ground level can one put an IP66 enclosure with a exterior gland on swa entering the bottom of the enclosure?
Ignoring the table below - what's best practice?
IP First number - Protection against solid objects
0 No special protection
1 Protected against solid objects up to 50 mm, e.g. accidental touch by persons hands.
2 Protected against solid objects up to 12 mm, e.g. persons fingers.
3 Protected against solid objects over 2.5 mm (tools and wires).
4 Protected against solid objects over 1 mm (tools, wires, and small wires).
5 Protected against dust limited ingress (no harmful deposit).
6 Totally protected against dust.
IP Second number - Protection against liquids
0 No protection.
1 Protection against vertically falling drops of water e.g. condensation.
2 Protection against direct sprays of water up to 15o from the vertical.
3 Protected against direct sprays of water up to 60o from the vertical.
4 Protection against water sprayed from all directions - limited ingress permitted.
5 Protected against low pressure jets of water from all directions - limited ingress.
6 Protected against temporary flooding of water, e.g. for use on ship decks - limited ingress permitted.
7 Protected against the effect of immersion between 15 cm and 1 m.
8 Protects against long periods of immersion under pressure
you don't want moisture from the ground seeping up your gland. seen it happen. i would ensure there's at least 6" below the bottom of the boot
If you are worried about the ingress of water, spend an extra few quid on the glands you use and go for one of these babies - Hawke 501/453 universal gland.
Bog standard, universal for use on armour or braided cables in hazardous areas / offshore / marine.
Ingress Protection: IP66, IP67 and IP 68 (30 metres for 7 days) to IEC/EN 60529 and NEMA 4X.
[ElectriciansForums.net] IP66 Enclosures - how low can they go?
Thanks for the replies, the box I'm putting in is on the side of a top step on a bank, overall a dry area due to the bank. Whilst its in free air at the moment, over time I'm sure there will be a build up of soil and the box will get half burried. I think I'll place one or two bricks around it to asist drainage keep the soil back, I can't see it being a problem.
Reply to IP66 Enclosures - how low can they go? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
