ir problem | on ElectriciansForums
Discuss ir problem in the Australia area at ElectriciansForums.net
A
adelecplum
any ideas, putting a spur on 3 year old ring rcd protected, ph-n ir 0.003meg, nothing connected
The RCD has no relevance to this problem ,it will only detect Leakage to Earth !
-Either something is still in circuit [likely] or you have a serious I/R problem on P-N
spark1
After splitting down the ring to narrow the problem area, in my case it turned out to be a short within the socket it's self.
Circuit proved clear, put socket back, fault reappeared. Removed socket and put new one on. Fault cleared.
Reply to ir problem in the Australia area at ElectriciansForums.net
If the main switch is on when testing global IR then the neutral and earth will likely give a very low reading. Not that anyone would...
loz2754
L
I
No water in shower head, pressure/flow problem Dear Professionals, could you please advise. I have standard mixer tap in my bath (its about 15...
IrinaPri
I
