ir readings (too low) | on ElectriciansForums
Discuss ir readings (too low) in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
bredon86
i have a low reading on a heater circuit. the circuit is feeding just one spur with a wall heater connected. reading are line to earth 1.21 all the rest are fine. please help... also can anyone tell the best way to rcd a 3036 socket circuit. either change board or indivually protect each socket??? cheerss
Sounds like the heater element is gone, or on it's way.
Have you tried testing after the heater has been on for a while?
You could run a lolipop style circuit, come out of the board in 6mm² to an enclosure containing an RCD, and the run the RFC from the enclosure.
Have you tried testing with the heater disconnected?
i have an doing remedial work on the socket circuit which has been tested by somebody else. One of the observations was no rcd protection so i thought that this needed doing. also i have disconnected the heater and stll a poor reading.
cheers
Reply to ir readings (too low) in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
That's a hell of a big jump to make, an RCD trips therefore a rewire is required! If a wheel on your van gets a puncture do you go out and buy a...
davesparks
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
