IR teating when RCBOS are in place | on ElectriciansForums
Discuss IR teating when RCBOS are in place in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
chopper
out of interest , if a DB is fed with armoured cable using the starnds as earth which is fed from a main isolater which is on a TNCS supply, to carry out the IR would i have to dissconnect the neutral out of the main isolter ( not on the DB ) and the earth fly lead off the banjo. when testing N to E. WoULD I ALSO have to dissconect the fly leads from the rcbo ( earth and neutral ) then i could simply test from load side of rcbo to earth terminals.
doing the above this would mean i could also test L TO N on load side of rcbo
and L to E stRAIGHT FROM LOAD SIDE OF rcbo and earth terminals
am i thinking right, i went to job today gaffer says me and him will be testing it so i was trying to think on how he would probly do it for the best way, it was a 16 way 3 phase so be loads to dissconnect
When IR or loop testing all RCBOs with a functional earth wire require this flylead to be disconnected during testing. Some manufacturers additionally require the neutral flylead to be disconnected and/or the RCBO switch dolly(s) in the OFF position during testing. Check the manufactures instructions, as not following their instructions risks possible misleading results and/or damage to the protective device.
Reply to IR teating when RCBOS are in place in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
It is not that they don't trip, it is that putting a probe in the front of the RCBO to contact the terminal bypasses the sense coil so the RCBO...
davesparks
Yup will do exactly that when I'm back down there. Thanks for the help
