IR test problem | on ElectriciansForums
Discuss IR test problem in the Australia area at ElectriciansForums.net
G
Gaz Bryan
Just finished chasin round a house tryin to find the cause of the 0M ohm reading on a ring circuit IR test. I spent about 45 minutes ruling out the central heating which was fed of the ring. Nope not that. So back to basics, break the ring, find out which half the problem is on. Several sockets later I find one which has an extra cable feed into the back of it. The cable was very neatly chased into the wall until it went behind a kitchen cupboard. The cable was clipped to the wall at the back off the cupboard and then along the wall above the cupboard to a wall clock. A **$@@/? clock.
And it was slow.
mind you 500 volts up its escapement should speed it up a bit!
Reply to IR test problem in the Australia area at ElectriciansForums.net
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
