Sparks74
Evening people
Right,doing a Periodic on some modular built studios & have a few questions i hope you guys can help me with,IR test on a lighting circuit with a few pir's,the pir's are not accessable,so i'm unable to disconnect then, so when doing a IR test is it right to test Live & neutral to earth? also should i be doing this test at 250v due to the electrical components with in the pir?
Also IR on a cooker circuit,would prefer to leave the DP cooker switch terminated due to lack of slack on cable,so when doing the IR test if i link the neutral on both sides of DP switch & again test Live & neutral to earth is this okay? & should i be done at 250v as the switch has a neon on it?
Any help would be greatly appriciated
