IR Testing... Am I missing a trick here? | on ElectriciansForums
Discuss IR Testing... Am I missing a trick here? in the UK Electrical Forum area at ElectriciansForums.net
Market Harborough
Hi,
I know this may seem like a stupid question, but here goes.
Example...
You have an existing RFC and spur off to a SFCU to feed a flood light for example.
Connect it up, do R1+R2, Zs etc,
but IR, I disconnect N and then run 250v as a start between L-N, then L-E, then N-E, then if all clear (acceptable reading say >100M), I do it at 500v and take the risk.
But first I go round the entire flaming house unplugging everything as there's no telling whats on what circuit, if its SP or DP sockets and just switching off may not be safe, or have missed something.
I know I can do it LN-E @ 500v, but am I missing a trick here?
My issue is, I get a lot of customers wondering why I am essentially interfering with the the rest of the house (unplugging stuff) just because I have fitted an outside light... People don't want me traipsing round their house when all they want is a new light.
I explain it to them, but what do you do? I feel I am doing too much.
IR test the wiring to the new light before you connect it to the existing wiring. then if you're fussy. test LN-E of the whole circuit with appluances left in.
IMO, you need to fully test what you are installing new. then ensure that the installation ( inc. the circuit you are adding to) is safe to connect to and is safe for continued use. this includes, of course checking earthing and bonding. sometimes common sense overrules blind obedience to regs.
1. Before conducting an alteration or making an addition to an existing installation, you will have first determined that the existing installation is in a satisfactory condition for you to make the alteration or addition.
2. You are required to inspect and conduct appropriate tests on the work you have conducted, recording the results on the certification.
3. It is prohibited to use either an EIC or MWEIC for the inspection and testing of an existing installation.
But not for an addition on or alteration of an existing circuit.
What Lee said above? If I was doing Uksparks job, I would do what Tel said. If I was doing something more extensive, major alteration of ring final, then I would do L-L, L-E, N-E test. What you feel is appropriate before re -energising circuit.
That's it, if I have extended a ring around another room or something like that, then it warrants a full set of tests.
Reply to IR Testing... Am I missing a trick here? in the UK Electrical Forum area at ElectriciansForums.net
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
2 3 4
6K
