Thanks - Yes it's a SFCU, I appreciate the correction.
Getting the terminology right will help me to ask better questions.
It is old, I'm not sure if it's double pole will check, if it's not I will change it.
That question was about my boiler, thanks very much.
With reference to a current question on the main forum.
I have a purley academic question.
http://www.electriciansforums.co.uk...ma-rcd-tripping-after-replacing-consumer.html
Someone connected a boiler to a new CU and it tripped the RCD.
If testing was carried out prior to fitting the new consumer I don’t believe this fault would have been picked up. I suspect possible water ingress, via the flue.
How is this situation handled, is it by informing a customer that vital appliances my not work after CU update ?
