Been doing pir testing on commercial building been shorting out ln and testing to earth. Been getting readings of 5 to 8 m ohms on some of the tracks i no this is an acceptable reading but i was wondering to may be make the client aware of the low readings or just leave it. Personally if it was my responsibly i would advise to lift flooring unplug every device thats plugged into the track and re test l n l e n e this would be very time consuming and also very costly any thoughts or advise would be much appreciated . This is an on-line shopping company and if they did loose power to pcs it would be very costly to the company
