Looked at a job a few days ago, CU change. Customer showed me a mangled lighting circuit cable in the airing cupboard, it looked like it had been chewed up! Circuit still working and in regular use though. I IR tested circuit L-N and picked up no problem, which initially surprised me but then I realised that L and N are run in 'single and earth' and follow different routes around the house. The only points they converge are obviously at the lighting points. Hence, the test I did was useless. True?
L-E, N-E also did not show a problem, except for highlighting that the CPC has no continuity through the circuit!
Obviously, I'll replace the cable, just talking theory here.
