With surge protection devices fitted they will provide protection to the circuit during a (IR) test, the test voltage will cause the protective components inside a surge protector to divert unwanted energy from the protected line.[SUP] [/SUP]This was know in the past as clamping voltages. By clamping the voltage in a circuit, this indicated better protection, but can sometimes result in a shorter life expectancy for the overall protective system. Generally you find that by applying a test voltage of 500v DC to a nominal rated circuit of 230v AC, will cause the clamp to give mis-direction in the readings in the (IR) test, so whoever told you to disconnect them during a test, gave you sound advice.
