C
CopperSplinter
Hi, first time poster here.
I've had a relatives iron come my way that is in need of a replacement mains cord but I'm a little confused as to what gauge the replacement flex should be.
It's stated on the bottom of the iron that it draws 2kW max, which just over 8.5 amps at 230V. According to what I've read online this means that I should use flex with 1.0mm[SUP]2 [/SUP]cores, but upon closer inspection the factory installed cord is only 0.75mm[SUP]2 [/SUP]flex which contradicts what I've read online regarding gauge vs current draw.
I'm guessing it has something to do with the heating duty cycle and cord length (2 metres in this case) but would like some advice before I go ahead and order something that may not be suitable.
Will .75 mil be suitable or should I just go with 1 mil to be safe? Also are there any regulations regarding the maximum cord length that can be installed on an appliance such as an iron, say 3 metres vs the factory 2 meters?
Any advice here would be appreciated.
Cheers!
Cheers!
