irwin hilmor conduit bender el25 | on ElectriciansForums
Discuss irwin hilmor conduit bender el25 in the For Sale and Wanted Forum area at ElectriciansForums.net
M
mike-h
conduit bender 20mm and 25mm £80 pick up only liverpool
Reply to irwin hilmor conduit bender el25 in the For Sale and Wanted Forum area at ElectriciansForums.net
I'm interested, where abouts are you located?
If you get a length of conduit, and seal both ends then the IP rating will instantly be IP68!! If you buy an IP66 rated Wiska box it will...
  • exceeding voltage drop
    The cable is way undersized. If the voltage drop is detrimental to the installation I would make...
  • TT advise
    OK My take on the precautions to implement when omitting an up front RCD on a TT system. Tails...
  • SIL vs ATEX
    Good morning all, I have a question for those who are CompEx and SIL aware - I have various Ex...
